tigger1972de
Dec 21, 2014Initiate
ReadyNAS DUO v1 and new ReadyCloud doesn't work- How to?
Hello,
I used ReadyNAS remote all time. Now I changed to Windows 8. But how can I connect to my two RND2000 ReadyNAS DUO V1. Both have the newest Firmware.
But ReadyCloud can't discover my NAS's. On the other side: my Samsung S4 can see both with the Android-APP ReadyCloud.
What must I do to see on my PC?
- NhellieVirtuosoThis is probably an issue that is being worked on, ReadyCloud was designed for OS6 units but some users (like you) are able to see their NAS using the ReadyCloud app on android phones. For your PC, try installing this and run compatibility for Win7:
http://www.readynas.com/contributed/mdg ... 6.5.23.exe- CapnOdysseyAspirant
Has there been any progress on ReadyCloud availablility for ReadyNas DUO v1
- JennCNETGEAR Employee Retired
Hello CapnOdyssey,
Welcome to the community!
Unfortunately, there is no plan getting ReadyCloud to work with ReadyNAS Duo or any legacy NAS. ReadyCloud is for ReadyNAS OS6 while ReadyNAS Remote is for the legacy NAS models (OS4 and OS5).
