Soiski71
Jan 13, 2021Aspirant
Readynas duo v2 not starting after power failure
We had yesterday powerfailure and now the unit will not boot correctly nor is visible in Raidar. After power up; Power button LED, USB and backup status LED, disk 1 LED, and disk 2 LED gets lights ...
Soiski71
Thank John,
Still the same when Disks removed. All lights (except activity) light up, but Raidar does not see it. Looking from my switch it does not get IP either , but the ethernet connector though is blinking as it would be doing "something".
Accessing the boot mode does not work either. Pressing Backup button only switches all lights out (as it does if rebooting with out reset button pressed on power on) so No recycling of boot mode possible.
JohnCM_S
Jan 14, 2021NETGEAR Employee Retired
Hi Soiski71,
Since you are still getting the same issue even without the disks, the issue is most likely with the chassis already.
It will be best to confirm first if your NAS is a Duo v1 or v2 because the product label of this NAS model can be confusing. One way to determine is to check the front panel of the chassis (The other labels on the chassis should be ignored). If it only has ReadyNAS Duo in it, then it is a Duo v1. If it says ReadyNAS Duo v2 on the front panel, then it is a Duo v2.
