illmatic
Sep 10, 2018Guide
requesting USB recovery for NV+ v2
I have the exact same problem as described here: https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-NV-V2-ARM-stuck-in-Boot-Normal-Mode/td-p/1377994
After a clean power down, now my NV+ v2 refuses to boot, it automatically goes into the Boot Menu where I can only select "Normal" However, after choosing this option it won't actually boot or do anything else. This occurs without pressing the reset button to get into the boot menu, although the results are exactly the same if I do press the button. It happens with disks in the unit, with disks out of the unit, or with new disks in the unit. Power to the unit seems fine, all the expected lights are on, the fan spins, the displays are active.
I am running Raidiator 5.3.12 or .13, not sure exactly which one, but I cannot access the unit to check. I have disks 1 and 2 as RAID-1, and disks 3 and 4 as a separate RAID-1. The disks appear to be ok, I can see the partitions, volumes and files in Linux when individually hooked up directly to a PC. (the beauty of RAID-1)
In the linked discussion, the user was able to resolve the problem using a USB recovery key, but the URL to the recovery key file no longer works. I'd like to download and attempt a recovery using the key, if it is available. Thank you.
- illmaticGuide
I will note that USB Recovery files are readily available for OS4 and OS6 but not for OS5:
https://kb.netgear.com/30267/RAIDiator-4-2-USB-Recovery-Tool
https://kb.netgear.com/21400/RAIDiator-4-1-USB-Recovery-Tool
Would be great if NETGEAR Support could lend a hand to those of us in the middle, using ARM-based systems on OS5.
- Marc_VNETGEAR Employee Retired
- illmaticGuide
Thanks for the recovery key files. Unfortunately I am not having success like the poster I referenced above. When I power up while holding the backup button, that button will flash continuously but nothing indicates that it is booting from the USB key. The LED is blank. I tried with a disk in slot 1 and without. I tried 2 different USB drives. I let the READYNAS unit run for a long time. The README is quite limited. The USB itself (after using the tool) has just 3 files on it. Any obvious things I might be doing wrong? Thank you.
photo: https://s8.postimg.cc/guafqgrb9/readynasusb.jpg
Hi illmatic
It could be incompatible USB keys, you may have to try a few more drives and it should be partitioned using MBR witha single FAT32 partition.
Also, only 3 files is expected including the firmware image. The NAS should reboot/power off once the USB recovery procedure is successful.
Regards
I managed to make a serial connection, after a lot of trial and error.
In case someone else needs to do the same, I used a USB-to-TTL cable with 4 strands that I purchased on eBay, it shows up in Windows Device Manager as "Prolific USB-to-Serial Comm Port." Make sure you look at which COM port it assigns, you'll need this. On the READYNAS unit (again, lots of trial and error) from Right-to-Left, I hooked up black (ground), green, white, and left the red (power) wire unconnected.
The serial connection setup is: 115200 baud, 8-bit data, parity: none, stop: 1 bit, flow control: none. You will need to set these parameters in both Device Manager and in Putty or TeraTerm.
The ouput is at https://justpaste.it/5xhow There isn't any indication of a failure, it just goes into the Boot Menu without really explaining why.
Any diagnostic help would be gretly appreciated.
- mdgmVirtuoso
You could have a problem with your reset button. It could be stuck in or a problem inside the case leading to the system thinking the reset button is pressed when it's not.
If you boot holding down the ESC key on a USB keyboard you should get into the u-boot console. From there you should be able to see if the u-boot environment is intact (but don't make any changes unless you know what you're doing).Have you tried doing USB Boot Recovery with the serial console connected?
