Peacekeeper357
Oct 12, 2017Aspirant
ReadyNAS Not Available In ReadyCLOUD
Trying for first time to add my ReadyNAS 104 to ReadyCLOUD. NAS can be seen in Discover tab of ReadyCLOUD, but not listed as a device in the Home tab. I'm kinda stuck. See screen caps below. Any idea...
- Oct 18, 2017
Hello Peacekeeper357,
If "leave cloud" and "rejoin to cloud" works for you, would you please mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution? so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Best Regards.
Oct 16, 2017Guru - Experienced User
Not sure if this is directly related to your problem, but 192.168.1.0 is normally not allowed. It's reserved as the network identifier.
- Peacekeeper357Oct 16, 2017Aspirant
Not sure where you're seeing that. The router is 192.168.1.1 and the NIC on the ReadyNAS is 192.168.1.6
- StephenBOct 16, 2017Guru - Experienced User
Got it, the 6 looked like a 0 in my browser.
