Peacekeeper357's avatar
Oct 12, 2017
ReadyNAS Not Available In ReadyCLOUD
Trying for first time to add my ReadyNAS 104 to ReadyCLOUD. NAS can be seen in Discover tab of ReadyCLOUD, but not listed as a device in the Home tab. I'm kinda stuck. See screen caps below. Any idea...
  • BingkeX's avatar
    Oct 18, 2017
    Hello Peacekeeper357,
    If "leave cloud" and "rejoin to cloud" works for you, would you please mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution? so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Best Regards.
ProSupport for Business
