tdaters
Nov 29, 2018Aspirant
Readynas Pro with os6 will not connect to Readycloud
i have an old readynas pro 6 with os6 installed. It won't connect to Readycloud because the nas spits out the mac address on eth0 as the serial number.
i have seen posts on a work around, just noth...
- Dec 11, 2018Hi tdaters,
The fix has been applied and the NAS has been rebooted to Normal mode. It should have the proper serial number now.
JohnCM_S
Nov 30, 2018NETGEAR Employee Retired
Hi tdaters,
Can you enable SDM (Secure Diagnostic Mode) on the NAS? We will try apply a fix for that problem. Please PM me the 5-digit port number after enabling it.
- Retired_MemberNov 30, 2018
I have the same problem
After Update to 9.4. and change the network DNS to 8.8.8.8 and restart the serialnumer change to NONE000200000.
I cannot use READYCLOUD.
It was changed before from stephenB and i could use Readycloud.
But after a restart i got again NONE and no connection to READYCLOUD
with best wishes
Jochen
- JohnCM_SNov 30, 2018NETGEAR Employee Retired
Retired_Member
Your NAS has a different cause on why it cannot connect to ReadyCLOUD. L3 tried accessing it remotely but it is unreachable. Please re-enable SDM so we can check again the issue on your NAS.
Regards,- tdatersNov 30, 2018AspirantThanks for helping
I have re-enabled sdm
Same port number
Thanks
Tim - tdatersDec 05, 2018Aspirant
I am taking the nas off line to replace the power supply.
Will send you a note when it’s back up.
Thanks for you help.
Tim
- tdatersDec 08, 2018Aspirant
New power supply is back in. The unit is back in sdm with same number.
thanks
tim
