tdaters
Nov 29, 2018Aspirant
Readynas Pro with os6 will not connect to Readycloud
i have an old readynas pro 6 with os6 installed. It won't connect to Readycloud because the nas spits out the mac address on eth0 as the serial number.
i have seen posts on a work around, just noth...
- Dec 11, 2018Hi tdaters,
The fix has been applied and the NAS has been rebooted to Normal mode. It should have the proper serial number now.
JohnCM_S
Nov 30, 2018NETGEAR Employee Retired
Retired_Member
Your NAS has a different cause on why it cannot connect to ReadyCLOUD. L3 tried accessing it remotely but it is unreachable. Please re-enable SDM so we can check again the issue on your NAS.
tdaters
Nov 30, 2018Aspirant
Thanks for helping
I have re-enabled sdm
Same port number
Thanks
Tim
Same port number
Thanks
Tim
