tdaters
Nov 29, 2018Aspirant
Readynas Pro with os6 will not connect to Readycloud
i have an old readynas pro 6 with os6 installed. It won't connect to Readycloud because the nas spits out the mac address on eth0 as the serial number.
i have seen posts on a work around, just noth...
- Dec 11, 2018Hi tdaters,
The fix has been applied and the NAS has been rebooted to Normal mode. It should have the proper serial number now.
tdaters
Dec 08, 2018Aspirant
New power supply is back in. The unit is back in sdm with same number.
thanks
tim
JohnCM_S
Dec 11, 2018NETGEAR Employee Retired
Hi tdaters,
- tdatersDec 11, 2018Aspirant
Thanks so much for helping out on this!!!!
Is there anyway to back this up so that if i get zapped i can take care of it myself?
thanks
tim
- JohnCM_SDec 15, 2018NETGEAR Employee Retired
Hi tdaters,
There is no means to backup the fix done on the NAS but, it was already set to be persistent even if factory reset is done on the NAS.
