Jr12
Apr 12, 2016Aspirant
Readynas vs readycloud
Brand new readynas204. All you terrible documentation sbows browser screens with "netgear readycloud' in upper left corner. All i ever see is "netgear readynas". Cant get the single windows 7 pro 64-b...
mdgm-ntgr
Apr 12, 2016NETGEAR Employee Retired
ReadyCLOUD has undergone some changes since it was first launched. So very old videos may be for the older versions of ReadyCLOUD.
Have you looked at the latest software manual (for ReadyNAS OS 6.4) and at the ReadyCLOUD FAQ ?
If you don't wish to use ReadyCLOUD you can use the local admin access instead.
Apr 12, 2016Guru - Experienced User
I'm not certain I know what you are trying to achieve. Are you wanting to use the NAS w/o ReadyCloud, or are you having trouble getting ReadyCloud to work?
Assuming the former, the usual way of accessing a network share is by entering \\nasname or \\nasipaddress into windows file explorer. Have you tried that, and if so, what result are you getting?
Jr12 wrote:
Cant get the single windows 7 pro 64-bit to connect unless i share all its drives
Not sure exactly what you mean here. is "its drives" referening to the NAS or the Windows system? When you say "connect" do you mean accessing the NAS shares with file explorer, or do you mean something else?
