AMK64's avatar
AMK64
ReadyNAS/ReadyCloud: How to set up a share with different access levels?
Hi you all,
I would like to grant different access rights to different ReadyCloud users at directory structure level. Suppose the share structure looks like this:
/topdir
   /subdir1
   /subdir2
user1 should be able to access /topdir and the directories below it (i.e. subdir1 and subdir2)
user2 should be able to access /subdir1 only
user3 should be able to acces - you guessed it - /subdir2 only
I know I can set up 2 or more individual shares and give the different users the access to the shares they need, but as I also have LAN access to that share, doing so would mess up that nice directory structure of the share and I'd end up with a lot of (mapped) network drives.
Any help on this topic is highly appreciated.
Thanks,
-Alois
  • Hi AMK64,
    As you know, for readynas, acl permission is set based on the whole share, not subfolder in share.
    If you want to set permision for subfolder in share, you can use setfacl command for subfolder in share to achive this. But i have a concern. Do you puchase your readynas in last 90 days( which is free support period ) or beyound of  90 days?
    If you are still in free Support period, strongley recommended don't turn on ssh service and use setfacl  command.
    If you are beyound of 90 Days and you don't mind, you can turn on ssh service and use setfacl command to achive your goal.
    You can setfacl for user2, user3. For example: Under topdir,
    setfacl -R -m user:user1:rwx subdir1
    setfacl -dR -m user:user1:rwx subdir1
    setfacl -R -m user:user2:--- subdir1
    setfacl -dR -m user:user2:--- subdir1
    setfacl -R -m user:user2:rwx subdir2
    setfacl -dR -m user:user2:rwx subdir2
    setfacl -R -m user:user1:--- subdir2
    setfacl -dR -m user:user:--- subdir2.
    PS: If you setfacl with shares or subfolders with setfacl command, don't change "File Access" tab for the share again. As it maybe impact on facl for share.
    Hope it is useful.
    Best Regards.
1 Reply
  • BingkeX's avatar
    BingkeX
    NETGEAR Expert
    Hi AMK64,
    Hope it is useful.
    Best Regards.
ProSupport for Business
