424User
Sep 28, 2016Tutor
Recently updated firmware on RN104 now users not able to backup pics from phone with Rcloud
I use the ReadyNAS 104 for my family to backup photos. I made sure everyone had a mynetgear.com account upgrade and they were able to access/backup their photos. The firmware up for 6.5.2 was avail...
JennC
Sep 30, 2016NETGEAR Employee Retired
Hello 424User,
Please check if her account can still see the NAS when logged in via ReadyCloud portal which is readycloud.netgear.com. If she is not able to see the NAS under Home, backup the data she has in her home share using admin account. Then login your own account that has admin rights to ReadyCloud portal, under Manage you should be able to see her account added, remove it then re-add under Home tab.
Welcome to the community!
- DimitrisNOct 01, 2016Aspirant
Hi JennC,
I've done it twice... :( I updated the firmware to 6.6.0 and i done it again... Doesn't work for me :(
Any other suggestions?
Dimitris
RN104
- JennCOct 01, 2016NETGEAR Employee Retired
Hello DimitrisN,
I'm sorry but I think you are in a wrong thread.
- 424UserOct 01, 2016Tutor
Thanks Jenn,
I copied files to another folder but didn't change the name of the folder ( i believe this was giving me issues). Deleted her old account and created new one. I had to to this a couple of times as it kept failing. I renamed the folder to something else and finally this solution worked. Thank you.
