Doug6392
Mar 28, 2016Guide
Remove device from ReadyCloud android app
I can log into the ReadyCloud web interface and only find my 3 OS 6 NAS units. If I use the ReadyCloud android app, I also find an old NAS unit which I once used (or tried to) but which failed a few m...
- Mar 30, 2016
Closing as per PM.
Doug6392
Mar 30, 2016Guide
Yes, and I replied to it above: "Yes. I had 2 of them, and one failed. The other was repurposed to backup an OS 6 unit. I can't recall which unit is showing up in ReadyCloud (I changed the names of the units to reflect their uses, but it's one of the old names showing up) but it's definitely a legacy unit."
JennC
Mar 30, 2016NETGEAR Employee Retired
Hello Doug6392,
Have you tried swiping it to the left then tap Remove device?
