Doug6392
Mar 28, 2016Guide
Remove device from ReadyCloud android app
I can log into the ReadyCloud web interface and only find my 3 OS 6 NAS units. If I use the ReadyCloud android app, I also find an old NAS unit which I once used (or tried to) but which failed a few m...
- Mar 30, 2016
Closing as per PM.
kohdee
Mar 30, 2016Administrator
This might be a long shot, but if you signed up for a ReadyCLOUD ID with different case letters, and you don't login with that same case, it might not allow you to delete a device. See if you are logging in with the same case username and try again to delete.
