IScrewedUp
Apr 19, 2015Aspirant
RN 102 corrupt root
Hi there, I had two good RN 102 systems working (6.2.2). After a reboot of one of them, I could not reach that box from the readycloud. Intranet still worked. I tried to install an upgrade hoping that...
IScrewedUp
Apr 20, 2015Aspirant
Ixa: Factory reset is:
1. power Plug in
2. hold reset (in the back) while pressing the power button. (5 to 6 sec) until all leds int the front are on
3. presses the backup button (front low) twice (only the LED for HD 1 will light)
4. Press setup (in the back) again.
HD are WD green 2 TB
1. power Plug in
