ryanasimov
Oct 27, 2014Aspirant
RN102: Changing MTU from 1500 to 9000 & connection problems
I worked on this with ReadyNAS tech support and they were unable to reproduce it. I have a simple network with an Apple Airport Extreme doing the routing and feeding an 8-port Gigabit switch. The swit...
Oct 27, 2014Guru - Experienced User
Did you do your Mac Remote test on your local LAN or over the internet? Is is easy for you to test both?
On the RN102 side, remote should look like a different "virtual" network interface - which can have a different MTU than the physical ethernet. You should be able to see that with ssh.
