ryanasimov
Oct 27, 2014Aspirant
RN102: Changing MTU from 1500 to 9000 & connection problems
I worked on this with ReadyNAS tech support and they were unable to reproduce it. I have a simple network with an Apple Airport Extreme doing the routing and feeding an 8-port Gigabit switch. The swit...
ryanasimov
After changing the MTU to 9000 I can login to readycloud.netgear.com, but after displaying the name of my NAS it times out and says "Device Offline". If I connect to my NAS through my LAN by typing its IP into my browser the same thing happens. HOWEVER, if I use the Finder I can access the shares through the Finder.
I believe that SSH is a way of connecting to network devices through the Terminal, right? If so, I don't know anything about command line connections.
