hawke84
Mar 13, 2015Tutor
RN104 Router Ports to open
Hi, to make sure everything works well (things like readycloud) what ports do i need to open on my router? ive got port 80 and 21 pointing to the readynas, do i need anything else for readycloud? (rea...
Nhellie
Mar 13, 2015Virtuoso
If you can access readycloud fine then there is no need to open a port for it. If you are asking what port it uses, the default is 6300 which you can also modify. Go to cloud>remote>settings
