hawke84
Mar 13, 2015Tutor
RN104 Router Ports to open
Hi, to make sure everything works well (things like readycloud) what ports do i need to open on my router? ive got port 80 and 21 pointing to the readynas, do i need anything else for readycloud? (rea...
Mar 14, 2015Guru - Experienced User
If you use FTP, you will also need to specify a smaller range of passive ports in the NAS, and then forward them in the router.
4 passive ports are enough for me. The port numbers you pick should be in the range 49152-65535.
FWIW, with firefox you can easily add an exception to eliminate the warning. I use both firefox and chrome, and with chrome I just click through it.
