rodcrit
Nov 06, 2023Luminary
rn204 factory reset
For a number of reasons I decided to do a factory reset on my NAS RN204. it is currently resyncing data. the problem is I cannot now access the system. RAIDar is connecting to the NAS and displ...
Nov 06, 2023Guru - Experienced User
rodcrit wrote:
it is currently resyncing data. the problem is I cannot now access the system. RAIDar is connecting to the NAS and displaying admin login page. but the password is obviously no longer valid and when I cancel it goes to the password recovery screen and reports there is no recovery set up for this system.
The default admin password for the RN104 is password.
rodcrit
Thank you for response. I had actually found some information in some old netgear documents. it looks like I am in business now.
A supplementary question... the nsa name has been defaulted to a default network address - 10.20.30 for example. is it possible to change this to a name : rodnas for instance?
must have done this 7 years ago when first installed the system, but memory not that good and cannot find anything in the old documents.
many thanks for contact
Rod
- StephenBNov 06, 2023Guru - Experienced User
I suggest downloading these manuals:
- https://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
- https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
The information you want is on page 188 of the software manual.
Go to system->overview in the web ui. (This should be the page you see when you log into the web ui).
There is a gear next to the NAS hostname. Click on it.
