paulinde
Aug 24, 2016Aspirant
RN214 Readycloud offline on web, OS 6.5
Have been able to access via Readycloud for a couple of months with no issue. Now when I try to access via web either via the www.readycloud.netgear.com or the Win7 client, I am getting an offline. ...
- Aug 25, 2016
Have had a bit of success. I deleted the settings and re-did them on the NAS. This has allowed me to access via the webb using www.readycloud.netgear.com, however the desktop client no longer shows "offline" but is stuck on "connecting". I un-installed the client re-downloaded and re-installed, no joy as to the client. Seems a bit strange as all was well for at least a couple of months.
Brian, the OS is current at 6.5.1, and the cloud tab shows green checks.
mdgm-ntgr
Aug 24, 2016NETGEAR Employee Retired
Have you checked for double NAT?
If a static I.P. address is set for the NAS in the local web admin page have you checked the DNS Server addresses specified to make sure they are still accurate?
paulinde
I should have mentioned, Readynas is static, IPS is dynamic. My router has DDNS and I have no problems with other devices which I use with use that service. It just seems like the ReadynasCloud is not getting updated if it is a IP address change. I am only guessing that the IP address may have changed, have not been tracking it, but the fact that ReadynasCloud is lost in the sauce made me think that was possibly the issue.
Paul
