paulinde
Aug 24, 2016Aspirant
RN214 Readycloud offline on web, OS 6.5
Have been able to access via Readycloud for a couple of months with no issue. Now when I try to access via web either via the www.readycloud.netgear.com or the Win7 client, I am getting an offline. ...
- Aug 25, 2016
Have had a bit of success. I deleted the settings and re-did them on the NAS. This has allowed me to access via the webb using www.readycloud.netgear.com, however the desktop client no longer shows "offline" but is stuck on "connecting". I un-installed the client re-downloaded and re-installed, no joy as to the client. Seems a bit strange as all was well for at least a couple of months.
Brian, the OS is current at 6.5.1, and the cloud tab shows green checks.
BrianL2
Aug 24, 2016NETGEAR Employee Retired
Hi paulinde,
I have a couple of questions that can help us resolve your issue.
- Can you still get automatic (firmware) updates on your ReadyNAS? How about downloading apps from the apps tab?
- What is the status of internet & services under the Cloud tab?
Looking forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
paulinde
Aug 25, 2016Aspirant
- BrianL2Aug 25, 2016NETGEAR Employee Retired
Hi paulinde,
Have you considered using another ReadyCLOUD account that will act as admin? Or perhaps a new one? I suppose your desktop client is now updated to 1.13. Can you also confirm if your e-mail (ReadyCLOUD account) is used as a registered e-mail address by one of your local ReadyNAS users?
Kind regards,
BrianL
NETGEAR Community Team- paulindeAug 25, 2016Aspirant
Brian
I was sitting here reading your messaage, and started up the client to check version (1.13), after sitting there for about a minute it connected! Must be the 20th time I tried it today.
Paul
Hi paulinde,
Great! Continue to monitor your ReadyCLOUD access using the desktop client. I also suggest that you try accessing your ReadyNAS using the ReadyCLOUD web portal or the mobile apps and report back if the issue persists.
Kind regards,
BrianL
