Mr_HoneyDo
Mar 17, 2019Aspirant
RN516 - Won't connect to ReadyCloud since 6.9.5 update
Since I've updated to FW version 6.9.5 I can't get the ReadyCloud App on either of my Samsung S9 phones or access my device via the ReadyCloud site. I appears, but says there are no volumes, and the...
- Mar 17, 2019
So I fixed it. I was looking for your two green check marks when I noticed it said no internet available. Somehow my port aggregation got changed from Layer 2+3 to Layer 3+4. Switched it back to Layer 2+3 and now its working again.
Mr_HoneyDo
Mar 17, 2019Guru - Experienced User
The xmit hash only affects the coin-flip that determines which NIC is used to transmit each packet. It doesn't affect internet connectivity.
But changing the setting would restart the NICs, and that might have done it.
- Mr_HoneyDoMar 18, 2019Aspirant
Everything is working. Something more must be going on with the xmit hash and the Ready Cloud service because it completely resolved the issue. I had restarted, shutdown and restarted, toggled the service and even restarted my switch and nothing changed the behavior until I corrected the Layer selection. End of the day its working, but I would be curious to hear Netgear chime on what might have been going on there.
- StephenBMar 19, 2019Guru - Experienced User
It would be interesting to know if the problem recurs if you change the hash back to layer 3+4. If it does, it'd be useful to know if the only symptom is disrupting the ReadyCloud service. If there is something broken in LACP I'd expect it to affect all services.
FWIW, layer 2+3 hashing guarantees that the total flow from the NAS to a client can't exceed the link speed of a single NIC. This guarantee can prevent packet loss if the ReadyNAS NICs are gigabit and the path from the NAS to the client is also gigabit . In other cases (for instance WiFi), the application relies on TCP congestion control (or UDP retransmission).
Layer 3+4 hashing doesn't have that guarantee, since traffic to different TCP/UDP ports can use different ReadyNAS NICs. So the NAS can attempt to send more than 1 gigabit of traffic to the client. I think that's very unlikely to trigger issues with ReadyCloud, since most ReadyCloud users don't have gigabit internet service. Those users are relying on TCP congestion control anyway.
- Mr_HoneyDoMar 19, 2019Aspirant
Switched it back to Layers 3+4 and working just fine. So definitely was just the NICs acting up. Odd that a restart and especially a shutdown/restart wouldn't have resolved that previously.
