koolfrank87
Dec 29, 2015Apprentice
silent install - ReadyCloudSetup.exe
Can anyone provide me with command line support for the ReadyCloudSetup.exe application? I would like to install this silently or with no user interaction but have had no luck with getting the switches I need.
Any help is appreciated.
- JennCNETGEAR Employee Retired
Hello koolfrank87,
Which ReadyNAS unit are you using?
ReadyNAS OS6 has ReadyCloud built-in. The legacy units cannot use ReadyCloud since they are using OS4 (OS5 for the Duov2 and NV+v2), though some users successfully loaded OS on them.
- koolfrank87Apprentice
I have the 316 but my question is directed at the Window application, not the physical box.
- siignaNETGEAR Employee Retired
The Windows installer for ReadyCLOUD does not currently support silent installation. We're looking into implementing this in the future.
