EnochPowell
Jul 13, 2017Aspirant
Ultra 4 remote access not working
Cannot get remote access to work any more. Remote access seems to have become readycloud which has become a netgear account yada yada. Spent ages trawling the internet for an explanation but netgear...
- Jul 24, 2017
Hello EnochPowell,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JennC
Jul 14, 2017NETGEAR Employee Retired
Hello EnochPowell,
You cannot use ReadyCloud account on a ReadyNAS Remote app and on a legacy unit (ReadyNAS OS4 and OS5). If you have upgraded your account to ReadyCloud, can you check please if you will still be able to login at remote.readynas.com? Use the old userID which is not in an email address format. If you are no longer able to login, I guess, it is best you create a new account and manage ReadyNAS Remote using the FrontView of your ReadyNAS and add your new ReadyNAS Remote account.
