firstpage
Nov 24, 2017Aspirant
Unable to join the device to the readyCLOUD
I am attempting to configure ReadyCloud. After a few hours of account creation problems, I managed to past that stage, but now I am stuck on the next stage. I get the following error after entering the login details:
"unable to join the device to the readyCLOUD. your device may be misconfigured"
I have checked the KB article of the same name, but no luck. I have a static address and verifed that the DNS and gateway addresses are entered.
Any ideas? The device is a two year old RN312 with firmware 6.7.5.
Check on the web ui cloud page to see the ReadyCloud status - there should be two indications - one for the cloud, the other for internet connectivity. Though I don't recall if those indications were both present in 6.7.5 (current firmware is 6.9.1). So you might consider updating the firmware.
Sometimes using google's public DNS (8.8.8.8) gives better results than the ISP's DNS. There's no good technical reason why that should be the case, but it sometimes does seem to work around connectivity issues.
- firstpageAspirant
Thanks Stephen. I will be trying this on Tuesday and report back.
On a side I contacted support via the emil [email protected] 8 days ago and are yet to receive a response! When I chatted in I was told that there were too many client on hold and I should try again later, not so great service.
- firstpageAspirant
Well it looks like the good ol' firmware update fixed the issue. Thanks for your help.
Update in case anyone else comes across the same issue.
