uffgnu14
May 19, 2016Luminary
Viewing/browsing in ReadyCLOUD Portal not working
ReadyNAS Ultra2 Plus RN OS 6.5.0 ReadyCLOUD Portal Windows 10 Home Hi Browsing/previewing pictures (JPEG:s) over ReadyCLOUD Portal doesn't work. Had this problem also with OS 6.4.2. Us...
- Aug 12, 2016Hi mdgmBrowsing with MS Edge now working.
Solved with new 6.5.2 (beta) and MS Windows 10 update, don't know which did it.Regards
Ulf
BrianL2
May 24, 2016NETGEAR Employee Retired
Hi uffgnu,
I answered your posts before and I tested this again but haven't duplicated the issues that you have. My ReadyNAS access via ReadyCLOUD had been flawless since the migration and update a week ago.
2 laptops Windows 10 Pro 64-bit and Windows 8.1 Pro 64-bit.
Web browsers like Google Chrome version 50.0.2661.102m and MS Edge 25.10586.0.0.
Had 20 plus photos in one of the shares (under the data volume) that I have R/W access.
Kind regards,
BrianL
NETGEAR Community Team
- uffgnu14May 25, 2016LuminaryHi BrianLThank's for your response. To bad you could not repeat the things I found.I tested some things but with no luck; router settings, Windows administrator/standard account, WIFI/wired-PC:s.
One thing that did a small difference for a short moment was by selecting "Stay signed in" when signing in with readycloud.netgear.com,
then I could preview a couple of more JPEG:s before I got to the broken state.Regards
Ulf
