uffgnu14
May 19, 2016Luminary
Viewing/browsing in ReadyCLOUD Portal not working
ReadyNAS Ultra2 Plus RN OS 6.5.0 ReadyCLOUD Portal Windows 10 Home Hi Browsing/previewing pictures (JPEG:s) over ReadyCLOUD Portal doesn't work. Had this problem also with OS 6.4.2. Us...
- Aug 12, 2016Hi mdgmBrowsing with MS Edge now working.
Solved with new 6.5.2 (beta) and MS Windows 10 update, don't know which did it.Regards
Ulf
uffgnu14
May 25, 2016Luminary
Hi
I have to add that the problem is with MS Edge, working fine with MS Internet Explorer.
A Microsoft/Netgear problem or some browser settings?
Regards
Ulf
Ulf
- BrianL2May 25, 2016NETGEAR Employee Retired
Hi uffgnu14,
Thanks for the providing feedback. What is the version of MS Edge installed in your Windows 10 PC? Are you getting the same behavior on your other machines (PC? MAC?)
Kind regards,
BrianL
NETGEAR Community Team- uffgnu14May 26, 2016LuminaryHi BrianLThe version is MS Edge 25.10586.0.0 with MS EdgeHTML 13.10586 (10586 is about W10 OS version i think) on both PC:s.
I'm getting the same behavior on WIFI-PC1 and wired-PC2.
The PC:s are up to date configured using W10:s automatic updates.Regards
Ulf- BrianL2May 29, 2016NETGEAR Employee Retired
Hi uffgnu14,
I will consult my colleagues to see what we can do to help you resolve this issue.
Kind regards,
BrianL
