mvlaran
Oct 11, 2022Aspirant
Volume Degraded without errors
Hello!
I have a ReadyNas 104 with 2 WDC WD40EFRX-68WT0N0 4TB NAS HDs.
Out of the blue, the system started to show the 2nd HD as DEGRADED.
I have destroyed, reseted the hole system and formatted both HDs. If I leave just the first one running it seems to be ok. If I plug the second one, it says that the volume is degraded, and if I run a test it shows that disc failed in the test, but without saying WHY it failed.
There is any kind of error or warnings other than "volume degraded". If I plug the HD in another CPU, I can format and use the HD without any warnings or errors.
No matter what I do, the system show that this volume is degraded.
Any suggestions on what to do?
Replace the disk.
Getting another WD40EFRX is fine, you could also get a 4 TB Seagate Ironwolf. Avoid the WD40EFAX, as it is SMR.
Not a definitive test. You could try testing it with WD's dashboard software. But it's pretty clear that the NAS is not happy with the disk.
- mvlaranAspirant
That's what I'm thinking, replacing the disc! I've already disconnected it.
Is it possible to downgrade the RAID 1 to JBOD so the unit stop flashing "DEGRADED" all over while I can't afford a new disc? (I'm brazillian, it's very expensive to buy a new HD now... I will have to wait a few months until I can get a new one.- StephenBGuru - Experienced User
mvlaran wrote:
Is it possible to downgrade the RAID 1 to JBOD so the unit stop flashing "DEGRADED" all over while I can't afford a new disc?If you are using the web ui, that would require destroying the volume and creating a new one. You'd need to reinstall any apps, recreate the shares, backup jobs, and similar stuff. And restore all the data from a backup.
There is a way to do it with the linux command line (ssh), but I don't recommend going that route unless you already are comfortable with linux. Also, it's best to make sure you have an up-to-date backup if you go that route.
FWIW, you should make sure you have your important data backed up anyway, as it is quite possible that disk 1 will fail while you are waiting.
