davesumm
May 25, 2017Luminary
VPN Disconnected as of 2017-05-25
I'm currently Online (VPN disconnected) again. Is this an anomaly or is there yet another Netgear fail?
- May 30, 2017
Turns out all i needed to do was restart the desktop client :P
Retired_Member
May 25, 2017Hello Davesumm
can you please check if Leaf network interface of your Windows has obtained IP address from server?you can go to Network and Sharing Center>Change Adapter Setting>Leaf Networks Adapter>Details,correct IP should be 5.*.*.*,have you installed any firewall application on your Windows?
