davesumm
Jan 29, 2017Luminary
VPN Disconnected
Hi, all
Is there any new known problem with readycloud? I'm struggling to connect to 2 different NAS systems remotely from my work PCs (2 different PCs) I am getting the dreaded online (VPN Disconnected) message and it's driving me daft
Thanks
The VPN disconnected was due to a problem with the VPN server. We resolved the issue middle of last week. Anything you are experiencing since middle of last weeks is unrelated to the main issue that occurred on the server at the end of January.
- mrselyodAspirant
I am having the same issue today -was working fine last week. I'm just trying to upgrade the client to see if it makes any difference.
Edit: It didn't.- LilRosAspirant
Have same problem today, normally fixed quite quickly but today not! Just called tech support and weren't aware of problem! I'm told its now logged and should be fixed soon! Finger crossed as I've got grumpy users today!
- BrendanMNETGEAR Expert
We are seeing multiple customers reporting similar problems. The engineering team are looking into it with high priority.
- rvillaAspirant
I am also experiencing issues. Fine last week, now I have 5 remote users without connection.
- Rightway_envAspirant
Same here, I've been rebuilding a laptop for our team due to HDD failure. When reinstalled Readycloud initially worked but after I had installed Teamviewer I got the VPN disconnected message. I thought it might have caused an issue but it's unlikely Teamviewer would have affected it. After 2 more rebuilds and installs (without teamviewer, though that's probably irrelevant) I'm getting the same problem. I will be able to test oure other machines later today but it looks like this is a wider issue.
- prauAspirant
Hi,
I have this problem too. I'm unable to login with PC clients to ReadyNAS Remote. Nothing in my networks was changed, FW permitions are OK.
I'm only able to login directly on web page https://remote.readynas.com/. NETGEAR changed somethnig again and stopped something working :-/
Thanks for solution.Premek
- Ive tried owncloud. Its outdated for the nas. Doesnt work.
nextwavepc wrote:
Ive tried owncloud. Its outdated for the nas. Doesnt work.It does work actually, but you might need to get the install package from rnxtras.com
- kokoschAspirant
Unfortunately still disconnected
- jlibAspirant
Netgear, please fix this. none of my windows pc's can connect. It works on my android and ios devices.
- mc41AspirantNo comments from HQ. 😡
Hi,
i have the same issue since 3 days,
No upgrade done, no apparent change on the structures.
VPN disconnected - android function well - webpage OK
- hydrafiAspirant
me too, I reinstall app in windows 10 but no effect, remain "online(disconnected vpn)"
FYI
i try using thetering by my phone without result.. still try othe ways..
This is ridiculous! When is Netgear going to make an official annoncement about this?
For many users the remote access function was one of the key atractions of a NAS.
Having convinced some of my users Netgear ReadyNAS was THE way to go, I'm now getting lots of flack that they should have used a Cloud service like Google Drive or Mcrosoft's One Drive. How can I argue when we are having a major outage like this and NO support?
Grrrrrrr!
- flattenedApprenticeI have restarted the NAS and now have a connection. I could be lucky, it could be temporary or maybe it is "fixed".
Andy.is this still working for you?
the restart of the nas?
has anyone else restarted since yesterday?
- Retired_Member
I have restared multiple times with the same result: VPN dissconnected or more recently "offline"
