davesumm
May 25, 2017Luminary
VPN Disconnected as of 2017-05-25
I'm currently Online (VPN disconnected) again. Is this an anomaly or is there yet another Netgear fail?
- May 30, 2017
Turns out all i needed to do was restart the desktop client :P
davesumm
I have an IP address beginning with 5 and no, I haven't installed any firewall. Was working fine earlier and now it's gone **bleep**-up
Retired_Member
May 25, 2017Can you reboot the NAS?I just connect to my NAS and able to get VPN connection
- davesummMay 25, 2017Luminary
I rebooted the NAS 5 minutes after I created this thread. Problem existed so I checked readycloud on the web and there was a firmware upgrade. I downloaded & rebooted it but it didn't fix the problem
- Retired_MemberMay 25, 2017
Can you send logs? thanks
I am at work so I can't access the logs until I get home, which is also where my NAS lives.
