davesumm
Jan 30, 2017Luminary
VPN Disconnected
Hi, all Is there any new known problem with readycloud? I'm struggling to connect to 2 different NAS systems remotely from my work PCs (2 different PCs) I am getting the dreaded online (VPN Disco...
- Feb 08, 2017
The VPN disconnected was due to a problem with the VPN server. We resolved the issue middle of last week. Anything you are experiencing since middle of last weeks is unrelated to the main issue that occurred on the server at the end of January.
Feb 02, 2017Guru - Experienced User
Is the iPad using the same credentials you are using with the portal?
