Pete10p
May 22, 2021Aspirant
admin login keeps cycling every 2-3 seconds
I have just upgraded to 6.10.5 and now I can't get into the admin page. I can log in as usual but after 2-3 seconds I am asked to log in again. This keeps cycling. I have cleared the browser caches...
May 22, 2021Guru - Experienced User
Pete10p wrote:
I have also reset the OS. With the OS reset to default it works OK until I restore the config and then the same problem occurs.
That is interesting. Do you have ReadyCloud (or other cloud apps) turned on in your original config?
Pete10p
No, none
Im justing trying to revert back to te previous version. but reinstalling the config is proving to be a problem with unknown server message popping up when trying to restore the file
