cstern
Aug 31, 2011Aspirant
Bug: router IP not updated when changing ip of network
Hi, Due to some internet provider imposed changes in my setup, I had to change the IP addresses of my LAN from 192.168.1.x to 192.168.2.x. This works fine, except that Readynas Photo II apparantly s...
yoh-dah
Sep 08, 2011Guide
cstern wrote:
yoh-dah wrote: Can you try resetting your router?
Do you mean power cycling it (done that) or erase the config completely?
All other appliances, incl webcams work as expected.
Just power cycling.
