Darth_Vader
Apr 24, 2013NETGEAR Employee Retired
How to setup ReadyNAS to work with Genie Marketplace
A lot of people are having problems setting up ReadyNAS to work with Genie Marketplace. Hopefully these steps will resolve the problems. Note: This instruction is only applicable to ReadyNAS with firm...
Leia
No, it's no need to reboot unless the app requires. All you need to do is waiting the app installation completed, it will pop-up an event log like "xxx app has been installed succuessfully" under the menu bar. Then you can go to Apps->Installed page, and click "Refresh" button. Then you can see the app you installed listed there.
FenterSpooner wrote: So why is it when you purchase an app, you have to restart RN for it to show up in the "installed apps" tab? It should install and refresh automatically without a need for reboot (unless the app requires it which it should provide some sort of prompt telling you so).
