Plukkie
Nov 28, 2007Aspirant
How to startup custom services at boottime automatically
Hi, I just installed my first piece of code on the NV+, a streaming daemon "kissd". I wonder how I can get this service startup automatic at bootime on the Infrant? I discovered there's only one...
gknippels
Dec 07, 2007Aspirant
Plukkie,
I don't know if it is important but I registered the scripts with:
update-rc.d kissdx defaults 20
I saw that you used 60. To be honest I don't know if it makes a difference.
Also, I would briefly verify that your script line
/usr/local/bin/kissdx -c /ust/local/etc/kissdx.conf -d
does indeed execute without any problems if you just type it at the prompt. Also, you are sure that the older kissd deamon isn't running anymore? If it is, it blocks the port that kissdx also want's to use.
That's all I can think of right now.
Good luck
Good luck
