NN_Dave
Feb 24, 2014Aspirant
Issues installing packages as dependency of addon
Hi All, I'm developing an addon for ROS6 and have run into a really strange problem. My addon depends on PHP, Rsync, OpenVPN and Sudo. I've added all of these to the control file for the .deb bui...
NN_Dave
WhoCares? wrote: Can you post the relevant parts of your control file? The problem is that although I reported this as a bug in the beta phase of RNOS6, the script that determines what dependencies should get installed never got fixed. Thus it still chokes on some conditions like >= "version number" and the like.
-Stefan
Hi Stefan,
Thanks for your reply!
The control file I'm testing with now is:
Depends: readynasos (>= 6.1.4), php5 (>= 5.0.0), libapache2-mod-php5 (>=5.0.0), php5-cli (>=5.0.0), php5-curl (>=5.0.0), rsync(>= 3.0.9), sudo (>= 1.0), openvpn(>= 2.2.1)
I've also tried sudo and openvpn without the version numbers:
Depends: readynasos (>= 6.1.4), php5 (>= 5.0.0), libapache2-mod-php5 (>=5.0.0), php5-cli (>=5.0.0), php5-curl (>=5.0.0), rsync(>= 3.0.9), sudo, openvpn
Is there another way I can get the dependencies installed?
Thanks!
