Garthadam's avatar
Garthadam
itunes and iphone 7
I recently decided to copy my music library to the NAS system. I turned on the itunes function but cannot get my iphone 7 to connect. I realize that this is more of an iphone 7 problem but I get any ...
  • StephenB's avatar
    Jan 16, 2018
    The iTunes server in the NAS is reverse-engineered open source, and doesn't come from Apple.  Unfortunately no one has reverse-engineered the "home sharing" features in the real iTunes, and that is required in order to stream to an iOS device.  BTW, it also won't work with copy-protected iTunes music.
    You can either
    • install Apple's iTunes on a PC, keeping your music library on the NAS
    • install a DLNA client on the iPhone, and use ReadyDLNA or the Plex Server on the NAS
    • install Plex on the iPhone (using the Plex server on the NAS)
    If you have copy-protected music, then the only option is to use Apple's iTunes.
    Otherwise, if you want to stream to your phone when away from home, then I suggest trying Plex.
ProSupport for Business
