cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all,
Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports.
I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowest machine) would be replaced by the NAS but I'm actually trying to merge some other services onto the box which much luck so far..
One feature I'm working on porting is my Tivo transcoder. Essentially I have a small system that pulls programs off my Tivo, transcodes them and uploads (via WiFi/ethernet) to my portable media player. It means when I get home my media player syncs with my now-playing list so I can watch TV on the train too and from work. Since I work miles and miles away, I don't have time to watch TV at home so it's the only way I can watch TV..
I have the package working on the NAS, and I'm working on the integration with the front end (like managing black-lists and so on). I'd like to bump the speed of the processor but obivously the newer energy efficient <65W intel chips all seem to be 1333MHz FSB. Is this supported on this NAS? I know the warranty is void with this type of fiddling, but that is a risk I'm happy to take.. I also understand you wouldn't recommend an upgrade like this, but I would really like to know if it were possible..
I'll make all the code (mplayer is the driver behind the transcoding) available to anyone if interested.. but it is important to realise this is a Series 1 Tivo and an Archos 705/605 media player, not a common combination..
- bishoptfAspirant
mdgm wrote: All 6-bay units have a display on the front.
If you want to upgrade the CPU in a system running 4.2.x the best unit to get is a Pro 6. But you replace the CPU at your own risk.
I am looking at pro 6, I understand the risks also, I have been upgrading hacking stuff for many moons. From the pictures when they are off it was hard to tell that the top piece was part of the display, I see that now.
I just enjoy doing stuff like that, I have the ultra 2 and thought it would be nice to have more bays and came across the CPU upgrade, I am wanting to run plex in the future and that would be a good fit if I can find one at the right price, I don't need many of the bells and whistles just something that is reliable running NFS to serve up my data. I may end up just staying with my ultra 2 and spooling up a vm to run plex on, I have a 16 core box that I fold on that I could fire up a VM but thought that this might be something fun to play with. :) - I have one E7600 for sell.
50€ + delivery - renedisAspirant
noadvertise wrote: Hmm, ok well i answered my own question by checking the paths of ever hwmon2 and finding out they are file not found. Whereas all of the hwmon4 paths existed. So the answer is, swap out all hwmon2 for hwmon4. However, you can't just nano or vi the enclosure.db file. Doing so is what caused my odd fan 1 has failed message. I used an sqlite editor, scp'd the enclosure.db file down local, upon viewing the data, I found that its structure had a main list containing all the readynas models. I clicked my readynas model, edited the column "paths", replaced all hwmon2 with hwmon4, saved, and uploaded back to my nas, overwriting the old file (i of course made a backup first).
Once done, the readynas seems to be fully and properly functional now. No more errors and the "health" view properly displays everything.
If anyone gets stuck on this part, let me know, I'll up screenshots and more details.
I've changed all hwmon2 to hwmon4 in the enclosure.db.
The Fan fail message doesn't come back anymore but still does not display RPM's, although the status is green/OK
Sadly the voltage messages still occurs :( - renedisAspirantI've got a lot of help through a TeamViewer session and it works now!
My NAS Pro Business is changed to a NAS Pro 6!
All temp/RPM readings work now! - chirpaLuminaryAnyone tried an E5620? I have a few around, curious if they would work.
- fastfwdVirtuoso
chirpa wrote: Anyone tried an E5620? I have a few around, curious if they would work.
The Pro's CPU socket has 755 contacts. Intel says the E5620 has 1366. - chirpaLuminaryGood catch. Shows how closely I looked at them heh.
- CampusLuminaryJust wanted to let you know that I was able to upgrade my Pro Business from the slow E2160 to a much faster E7600 (30EUR on ebay) as well. Especially VirtualBox running Zarafa runs much smoother after enabling all VT-x features but also SqueezeCenter is now so much more responsive. I can only recommend this incredible upgrade. Temperature is a little higher when having high load (59/48 vs. 58/38) but lower when idling (56/24 vs. 58/25). My UPS also expects a longer remaining runtime (93 min vs. 88 min) when idling.
- menkelisTutorThought this link might be useful
http://www.cpu-upgrade.com/CPUs/Intel/Core_2_Duo/index.html - HibtekAspirantok, so I also upgraded a pro to an Intel(R) Core(TM)2 Duo CPU E7200 @ 2.53GHz with a small stop at an E6400, both work, ok but now the system health screen reports this
Device Description Status
Disk 1 Seagate ST31000528AS 931 GB , 36 C / 96 F , Write-cache ON OK
Disk 2 SAMSUNG HD103UJ 931 GB , 33 C / 91 F , Write-cache ON OK
Fan SYS 953 RPM OK
Fan CPU 2083 RPM OK
Temp SYS 54 C / 129 F [Normal 0-65 C / 32-149 F] OK
Temp CPU 16.5 C / 61 F [Normal 0-60 C / 32-140 F] OK
UPS 1 Not present
is a CPU temp of 17 correct?, the E2160 that was in there ran at 50-55 C
What do you use to create stress on the system?
