cpu8088
Jul 15, 2016Virtuoso
netdata NT not working
installed this app on my 2120 v2 and pro 6 running with xeon quad 3230 with firmware 6.5.1
both got error message showing
Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Apache/2.2.31 (Debian) Server at 192.168.1.xx Port 443""
what have i done wrong?
cpu8088 wrote:""
amazz20 wrote:
Looking at the syslog while turning the app on I get:
400699 Date Today 22:45:12 Host Ezekiel Messagetype Syslog Syslogtag apache2 ProcessID 22660 Message [error] (111)Connection refused: proxy: HTTP: attempt to connect to 127.0.0.1
:19999 (localhost) failedThe Apache web server is responsible for proxying requests to netdata so that you can go to https://NAS/apps/nastools-netdata instead of http://NAS:19999, and use the ReadyNAS user list for authentication. Those errors mean that Apache can't connect to netdata.
Running systemctl status fvapp-nastools-netdata via SSH should give a good clue as to what's going on. Do either of you have IPv6 disabled by any chance?
- JennCNETGEAR Employee Retired
Hello cpu8088,
Did you install from the Available apps or just manually?
I tried installing this from the available apps and it was successful and monitors the performance.
Can you try both?
- cpu8088Virtuoso
only tried from available apps
will try manual install and report back
- cpu8088Virtuoso
tried manual install on both nases
still the same
used firefox 47.0.1 and internet explorer 9
- amazz20Guide
I am having the same issue on my RN202 running 6.5.1, also have tried installing it both ways.
While watching the CPU utilization using iStat, while it is on, it is using 3 percent. So, it is doing something just not able to display it.
- NAStoolsLuminary
cpu8088 wrote:""
- cpu8088Virtuoso
ipv6 was disabled
now enabled under network and netdata NT is working
thanks
- NAStoolsLuminary
cpu8088 wrote:ipv6 was disabled
I thought that might be it. I have the default configuration of netdata set to listen on IPv6 loopback, which should listen on IPv4 loopback as well. Shouldn't need to have IPv6 enabled. I'll look into it.
- amazz20GuideYep it works here now as well! Thanks
