NT_2112
Dec 08, 2019Follower
Not able to install Portainer after upgrade to 6.10.2
Running 6.10.2 on a ReadyNas 424. After trying to install Portainer, the install fails and the ReadyNas admin login page appears. Portainer is not installed. I downloaded the logs via the web a...
tigerten
Jan 25, 2020Luminary
I have same problem, no solution so far. Have you figured out how to get it running? My porteiner won"t start at all. I have seen this person found a way around. But I have no clue how to do it.
- givememynamebakApr 03, 2020Luminary
Mhynlo just created a release that seems to work for me: https://github.com/Mhynlo/readynas-portainer/releases/tag/1.16.4-ml1
- yobanApr 12, 2020Apprentice
Hi there
Not wanting to hijack the thread as it is good to see Mhynlo create a fix, but was wondering how to update from version 1.16.4-ml0 which is runnign on OS6.9.5?
Will an update be available via "readynas app store"? Or could I load the latest DEB file from his gitub account and install, hoping it will not break any containers.
Thoughts or tips?
