McGarnagle
May 09, 2017Aspirant
NZBGet unpack not working
Hi
I currently have NZBGet set up so that all new downloads are downloaded into an "Incomplete" folder. I've then set NGBGet so that complete downloads are moved to a "Complete" folder, with sub-folders for each category.
However, NZBGet is unable to extract any files once they finish downloading. This means the un-extracted downloads remain in the "Incomplete" folder. I know that the actual downloads are fine, as I am able to manually extract the downloads, and move them into the Complee>categoy file myself. They are then processed and moved normally by CouchPotato/SickRage. My issue is that NZBGet cannot seem to extract any files automatically. Are there any steps i can take to solve this problem?
Model number is ReadyNAS 316, firmware 6.7.1.
- JennCNETGEAR Employee Retired
Hello McGarnagle,
You might want to see this topic where a user of this app gave some tips.
- JBDragon1Virtuoso
I'm going tohave to try this myself as soon as I can so that NZBGet will auto update as it should. It would be better if it was all setup with a simple DEB file as work, but I guess I can go and manually do it.
- McGarnagleAspirant
Hi JennC.
Unfortunetely that link didnt help (unless i've missed something). The NZBGet app works for everything except for unpacking. This is the thing i need to solve.- JBDragon1Virtuoso
I'm using a version, 17.1 I was able to easily install as it was a DEB version. So it Unpacks great for me. I've been using it for a while. But it can't Update through the software. Not that having the newest version matters to much. This is the version I'm currently using and it works just fine for me.
https://github.com/Mhynlo/nzbget/releases/tag/v17.1-6
After it's installed, it show up with any other App's on your NAS that's installed. It will show there what the Default login name and password is. Use those to get on and then you can change it to whatever you want.
Thanks JennC
I have tried contacting the developer, however unfortunetely they are yet to respond. I
