Pinkyg
Apr 03, 2017Apprentice
Plex not working after OS Reinstall
Hi All,
Over the weekend I had to do an OS Reinstall to gain access back to the rn214 admin page (due to the readycloud account deletions).
Since then PMS will not run. If I click on Plex in the admin page home screen I get "connection refused".
I have tried to remove and reinstall the app but with no success.
Any ideas what to try next?
Thanks
Geoff
- mdgm-ntgrNETGEAR Employee Retired
Update to 6.7.0 and try installing the app over the top of itself.
- PinkygApprentice
Thanks mdgm,
I wasn't aware there was a newer firmware, don't recall it popping up on the admin page.
I'll do that at the next opportunity and report back.
Thanks again
Geoff
- PinkygApprentice
Hi mdgm,
I've went to the NAS admin page and checked for updates. Message says I'm on the latest firmware.
For clarity I'm on 6.6.1
Thanks
Geoff
- PinkygApprentice
OK....I've downloaded and uploaded the new firmware, rebooting now.
Firmware can be downloaded from here :
https://kb.netgear.com/000038354/ReadyNAS-OS-6-Software-Version-6-7-0?cid=wmt_netgear_organic
- Blueray3Guide
In case this helps others: Could not access admin page via ReadyCloud or Raidar 4.3.8 on same network. Could not access RN 312 and 212. ReadyNAS Pro 2 had no problems. On the 312 and 212 I could access shares from the inhouse network, but not the admin page. Did a firmware reset and data was saved but Plex denied connection. Tried to remove Plex, removal unsuccessful. Clicking on admin page for finding new firmware said I had the latest (6.6.1?).
Read here there was a 6.7. Downloaded and installed it and Plex started right up. Seems like strange problems. Anyone know what they were?
Thanks
There was an issue on recent firmware where when you did a firmware update or OS Re-install the installed packages list could get a little messed up. This was resolved in 6.7.0.
- Blueray3Guide
Had the same problem this weekend....could not connect to a 312 or a 212 NAS.
Did a firmware reinstall. Data was intact, but Plex server was "not reachable". Tried to reinstall Plex server on RN212....reinstall failed. Tried to uninstall Plex on RN212 and the uninstall failed.Any ideas?
- PinkygApprentice
Hi Blueray3,
Seems to be the exact same issue as I'm having.
I'm not really sure what to do next. A firmware update has been suggested but my NAS doesn't see an update...
Thanks
Geoff
- Jul 15, 2018Retired_Member
