Pete10p
May 22, 2021Aspirant
admin login keeps cycling every 2-3 seconds
I have just upgraded to 6.10.5 and now I can't get into the admin page. I can log in as usual but after 2-3 seconds I am asked to log in again. This keeps cycling. I have cleared the browser caches...
Pete10p
May 23, 2021Aspirant
I’ve tried a simple password and the problem persists.
What I don’t get is why if I reboot the OS and sign in with the default "password" password it works ok. Changing the password seems to make the problem happen. I'm going try changing the default password to "password" to see if its the process of change that is causing the problem rather than the characters use.
I have also tried opening my firewall. Normally the ReadyNas units are isolated from the internet. This has note made any difference.
JohnCM_S
Jun 26, 2021NETGEAR Employee Retired
Hi Pete10p,
The fix has been applied. Can you check if you can now access the GUI with no issues?
Thank you.
