Pete10p
May 22, 2021Aspirant
admin login keeps cycling every 2-3 seconds
I have just upgraded to 6.10.5 and now I can't get into the admin page. I can log in as usual but after 2-3 seconds I am asked to log in again. This keeps cycling. I have cleared the browser caches...
Pete10p
Jun 26, 2021Aspirant
That seems to have fixed the problem. I really appreciate your help.
How do I apply the fix to my other ReadyNas. I reinstalled 6.10.4 do I need to upgrade to 6.10.5?
JohnCM_S
Jun 26, 2021NETGEAR Employee Retired
Hi Pete10p,
Yes, please update it first to 6.10.5, enable remote access to the NAS, then send me the 5-digit debug code via private message.
- Pete10pJun 27, 2021Aspirant
I have done the upgrade
access number 56195
- richard42ackJul 31, 2021Guide
Same problem here. No matter from which machine or OS, Netgear router will bounce back to the login screen on almost every attempt to click on the menus. How can I fix anything with this router if it won't stay logged in to the point I could actually do anything with it.
This behavior started yesterday. I have been unable, despite numerous tries, to get anything done or to even see what the problem might be. This is a WAC124
What do I do now to fix this?
I have tried disconnecting from the WAN, but it still comes back with 'checking the internet connection' (why? there isn't one) and then logs me out. I can, at most touch 3 menu items before it does this.
- StephenBJul 31, 2021Guru - Experienced User
richard42ack wrote:
Same problem here.
Sorry, no. You posted in the ReadyNAS forum area, and the issue here was solved with a hotfix from Netgear.
Your wireless access point problem is different, and you should repost it in the right forum area.
- SandsharkJul 31, 2021Sensei
If the NAS has no internet connection, then it cannot load HotFix1 to OS6.10.5 that fixes that issue.
- richard42ackAug 01, 2021Guide
Ah. OK. Thanks. This came up with a search, didn't notice that detail. Pretty similar from the very first message -- getting kicked out of admin. If anyone is able, my items here can be deleted (doesn't seem I can do that).
