Destne
Oct 15, 2021Aspirant
Readycloud for Android v2.0.7 (latest)
Hey all, Changes to Android are making access to Android/data in the device's internal storage increasingly difficult. Readycloud is able to download files from my NAS fine and writes them in Androi...
Destne
Oct 17, 2021Aspirant
After some more research a bit more info to share...
Android 11 only allows an app to access it's own folder in android/data. So when readycloud stores downloaded files there it can see them fine but it has no facility to let you list/access/play them . A few file managers can see them fine. But no other app can. So if I download my music, VLC (or whatever music player you use) for example will not be able to see it in android/data/com.netgear.readycloud/...
The share option in the android readycloud app doesn't worjk either.
This means that the only way to access the downloaded files is to use a file manager like x-plore (there are 1 or 2 others) to get into the directory and copy the files out to somewhere accessible.
This makes readycloud just about unusable. There is no known workaround for this.
It needs netgear to provide the most basic piece of functionality within the app, simply asking where to download the file to. But it seems netgear has no interest in supporting this software further?
