roeltjuhhh
Dec 25, 2016Aspirant
unrar problem nzbget
Hello im having a problem after updating my nzbget to version 17.1! Downloaden goes fine andere verifying alsof button when hé wants to unpack im getting error 64 on unrar. Someone can help me out? ...
- Dec 30, 2016
Hello roeltjuhhh,
It may be best to contact Mhynlo
This discussion might also help: https://community.netgear.com/t5/ReadyNAS-Beta-Release/NZBget-issues-with-firmware-6-6-0/m-p/1192298#M8888
Reagrds,
JennC
Dec 29, 2016NETGEAR Employee Retired
Hello roeltjuhhh,
Have you tried on a different web browser?
Welcome to the community!
roeltjuhhh
Dec 30, 2016Aspirant
ive looked into the log file :
Mon Dec 26 11:18:17 2016 DETAIL Par: All files are correct, repair is not required.
Mon Dec 26 11:18:17 2016 INFO Repair not needed for Spotweb Look Filterset (Spotnet Classic)(18-12-2016)/SPLFLTRST18122016.RAR
Mon Dec 26 11:18:17 2016 INFO Second unpack attempt skipped for Spotweb Look Filterset (Spotnet Classic)(18-12-2016) due to par-check not repaired anything
Mon Dec 26 11:18:17 2016 ERROR Unpack for Spotweb Look Filterset (Spotnet Classic)(18-12-2016) failed.
if i set par-verification on always the problem is gone.. but why checking and repairing forced if the files are oke
- JennCDec 30, 2016NETGEAR Employee Retired
Hello roeltjuhhh,
Reagrds,
- JennCJan 03, 2017NETGEAR Employee Retired
Hello roeltjuhhh,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
