tomiaurednik
Jan 13, 2017Tutor
VPN connection problem RN10400 - problems with synchronization
Hi, RN104 Ready Claud app VPN connection connected but I can’t access to my folders via win explore v: 6.6.0; v 6.6.1 Eth0, static IP (I have 4 NAS in 4 different locations) Proxy not set; prim...
FramerV
Jan 16, 2017NETGEAR Employee Retired
Hi tomiaurednik,
Can you try to do a ping test to the NAS, also; try accessing the NAS via IP instead of its name.
tomiaurednik
Jan 17, 2017Tutor
Hi,
also I can not access the NAS device with the ping command...
- FramerVJan 18, 2017NETGEAR Employee Retired
Hi tomiaurednik,
Do you have RAIDar installed?
This will detect the ReadyNAS locally. Once it does, click "Browse" and let me know if it opens.
- tomiaurednikJan 18, 2017Tutor
Hi,
To all my NASes I can access via LAN, but I can not access them when I connect via ReadyCloud app with a VPN connection. Therefore, I do not need a RAIDar. I think the question is specific enough?
Thank you for your efforts and assistance.
- FramerVJan 21, 2017NETGEAR Employee Retired
Hi tomiaurednik,
Thank you for your reply. Given the current status of your case, it might need a thorough troubleshooting. I would suggest that you get in touch with our support group for options on how to get support via phone. You should still be able to purchase a per-incident support.
