SueParks
Feb 10, 2023Aspirant
ReadyCloud VPN Disconnected
I recently received a new MacBook Pro with macOS Monterey Version 12.6. I cannot get my new computer to connect to ReadyCloud. I have tried every suggestion. I turned the ReadyCLOUD service in admin...
Feb 10, 2023Guru - Experienced User
ReadyCloud ends in a few weeks (4 April):
IMO your best option is to switch to an alternative.
SueParks
Feb 13, 2023Aspirant
Can anyone please recommend an alternative for a small company (15-20 people)?
- StephenBFeb 13, 2023Guru - Experienced User
What router are you using for internet service?
- SandsharkFeb 15, 2023Sensei
See ZeroTier-as-a-ReadyCloud-replacement for my recommendation. Unfortunately, some seem to be having issues with the installation at this point, so you may need to stay tuned for a solution to that.
