Kiddin
Feb 22, 2024Initiate
ReadyNas 526 Firmware 6.10.10 Plex update
After I did the server update to 6.10,10 I can no longer use the app installed directly on the server. Any reason or work around for this?
- Feb 22, 2024
Kiddin wrote:
After I did the server update to 6.10.10 I can no longer use the app installed directly on the server.
which is in the release notes for 6.10.10:
You should be able to downgrade to 6.10.9.
You might also need to apply the changes here (See posts 1 and 37):
Feb 22, 2024Guru - Experienced User
Kiddin
Feb 23, 2024Initiate
That is what I did thank you.
